Thread: Winterizing Summer Escapes AGP in Georgia
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    I have a vinyl blue pool cover...not sure if I should use it, but I will have lots of leaves in the pool shortly if I don't do something this week.
    What steps should I take to keep my pool winterized? After January 1st, it can get into the teens for a few days in a row, but most of the time it's between 20 and 32 during the winter.
    I still have the skimmer filter on it now, but have the 2100 gph sand filter I got from Walmart a couple months ago. Just not sure if I need to keep using the filter and treating the water through the cold winter months.
    Any advise is much appreciated.
    Julie
    12'x36" / 2100 gal/ AG / Krystal Clear Model 603 filter cartridge pump ( cleans surprisingly well for a $35 pump!)
    Jul 2011
    Central Califorina
    208
    Re: Winterizing Summer Escapes AGP in Georgia
    I live in sunny CA so no need for me to close. Todays ambient high was 73, my pool was 85 with the solar panel. Here is what little I know of closing.
    To properly close and protect from freeze you should drain below the skimmer and take the pump inside. Remove the multi-port valve from the filter, although you can leave the sand and the rest of the filter out out with a cover on if you like. You will need a good winter cover to keep debris/light out of the pool both of which will feed algae.
    The other option would be to leave it open and run the pump when it is below freezing.
    Unless it is difficult for you to get water I would drain and refill in the spring. 2000 gallons is not alot of water. You can spend aday setting it back up or a few days clearing the algae.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    When people talk about running the pump when it is below freezing i assume you are talking about air temperature correct?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by Durf
    Correct.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    I still have the skimmer pump attached to the pool. Haven't attached the new pump yet. I thought if it got below freezing I'd need to run the pump so I would then need to leave it connected. Did I miss something?
