Results 1 to 8 of 8
Thread: Suction side pool cleaner
    Oct 2007
    Valrico, FL
    542
    I am thinking about purchasing a pool cleaner. Due to the way my pool is setup, it needs to be either a suction side type or a robot. The robot types look to be too expensive. Doing some research on the suction side cleaners, it looks like there are two general types: units like the Zodiac Barracuda line and units like the Hayward Navagator line.
    My pool is enclosed within a screen room, so I do not have a problem with leaves and twigs etc. Anyway I would like to get some opinions:
    1. Which type is better?
    2. Within each type is one model better than another?
    3. Any other recommendations.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Check out ThePoolCleaner. I have one and it works quite well plus it works on less suction than most cleaners.
    Mark
    The Pool Cleaner is the only way to go.
    Authorized IntelliFlo Installer
    The Pool Cleaner
    Can this be used in a AGP?
    Gdog
    28' round 23k gallon AGP Vinyl Liner
    1.5 hp pump,Sand Filter,Polaris 65 8 gallon Liquidator
    sammm's Avatar
    North Richland Hills, TX
    257
    Our pool had a suction side cleaner (Kreepy Krawly) when we bought the house. Never did like it...never did a very good job IMO. I re-plumbed the suction jet for pressure and got a Polaris 360.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Sammm
    Could you explain how you did that? I'm interested in something like the Polaris 360. I have a Kreepy Krawly & I really don't like it either.
    Gdog
    Jun 2007
    Folsom, Ca
    7
    I really like the Polaris ATV when it works in place of a KK or Navigator, I can’t recommend the ATV do to reliability. I’ve seen some quit after just 3-4 months of use. I second Thepoolcleaner or Baracuda G4, have not heard anything negative on either yet.
    -Ryan
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,
    but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming
    "Wow! What a Ride!"
    15K IG Jandy Stealth 1hp, Jandy Aqua Pure 1400, Jandy CL 460 Cartridge, Jandy LXI Heat. Polaris Booster W/ 380 Cleaner Spa.
    sammm's Avatar
    257
    Re: Sammm
    Quote Originally Posted by Gardog
    My 'suction-port' was connected to a 3-way Jandy valve. I used the valve to turn that leg off. I then re-routed the plumbing and added a 'T' to tie in to the pressure side of the plumbing.
    If I had to do it over again I would just leave the plumbing as is (that thick PVC is hard to retro-fit because you can't 'bend' it to make stuff fit. I also cracked a Jandy valve and had to replace it during my project) cap off the suction port in the pool. There are 'safety covers' available that go in the pool. The 360 is made for those without a dedicated pump for their cleaner. You just use an existing jet and connect your 360 to it.
    Hope this helps.
