Thread: What to do with my Tri Chlor pucks?
    Hi,
    Amazing board!! You have saved me hundreds of $$$ and it was so easy after the first few weeks. Now, what can I do with these stupid tri-chlor pucks? I bought them before Pool School and haven't used them mainly due to my CYA being pretty high all season. In the 90's then 70's and now about 60. Should I throw them into a floater when I close the pool this week or throw them out? I plan on starting the shock tonight for a Thursday close.
    Thanks!!
    Joan
    Joan
    Baltimore MD
    22500 IG Plaster
    DE Filter
    I don't know the the filter info other than it's original equipment (1988) and the Pool Guy laughed when he saw it. My husband has repleced the motor a few tmes with the (Anthony Pool)recommended pump size.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: What to do with my Tri Chlor pucks?
    Well, I suggest that you save the pucks for vacations. They will last a long, long time.
    You're done SLAMing when:
    Thanks! I will store for next summer. One more question. I have 10 bags of Bio Guard Maintain Burnout 35 Lithium Hypochlorite. Here's my numbers for a closing Thursday:
    Chlorine 4.5
    Free chlorine 0
    Alkalinity 60 (Too low for closing?)
    Temperature 68
    Ph 7.5-7.8
    CYA 45
    Calcium 220
    Can I use this stuff for my shock to close? Thanks!!!
    Joan
    Joan
    Baltimore MD
    22500 IG Plaster
    DE Filter
    Butterfly's Avatar
    South Carolina
    10,045
    Yes, you can use the lithium hypo for shocking.
    I suggest you bump the TA up to around 70 or 80, using baking soda.
    Use the PoolCalculator.com to determine effects of increasing TA and any adjustments possibly needed for pH prior to closing.
