Thread: Brushed Concrete
    Brushed Concrete
    Decide to with regular concrete over stamped since i can only use pool 4 month ayear up here. This may be a dumb question but can you get this concrete without the brushed look? idont like the swirls/ridges just want a flat smooth finish. Any thoughts would be appreciated
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    Jan 2011
    Riverside, CA
    352
    Re: Brushed Concrete
    I think the main reason to 'brush' the concrete is to make is less slippery (mostly when wet).
    You could probably have a polished mirror finish if you wanted it, then you can ice skate all year around.
    My guys did NOT charge any extra for the 'wet' release stamp. It is literally a big rubber stamp they beat into the concrete with a stick (with a big flat metal plate on the bottom).
    http://youtu.be/8l_bOUvhqQU
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    Everything costs double here in MA must be nice to have an endless stream of cheap labor
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
