Results 1 to 11 of 11
Thread: AQUA GENIE leak x3
    Oct 2011
    15
    AQUA GENIE leak x3
    I've had it with the Aqua Genie skimmer and return Combo!
    I'm a pool profesional here in AR. I have 3 completly diffrent makes of IG pools with leaks that subside just below the Aqua Genie Jet/Return. I heard rumor that this could be fixed with a type of waterweld/ putty or a 2 part epoxy? If any one has experince with fixing this what I hear is a pretty common problem please let me know how you did it.
    I've heard remove the face plate and look inside the return and coat with glue?
    Thanks for the help!
    South Central NJ
    3,192
    Re: AQUA GENIE leak x3
    I hate them too. Darn PIA to winterize.
    The leak is likely the hose that leads from the return to the chlorination chamber that holds the tabs. Check the flow coming up with the tablet container removed. It should spout about an inch to an inch and a half above the water level. If it isn't, push the line in a bit and see if that makes a difference.
    Scott
    Owner of - PoolGuyNJ LLC
    Oct 2011
    15
    AQUA GENIE leak x3
    Actually on one of the Genies that feeder line is caped off. The others are in working order.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    If it stops below the return maybe the gasket needs to be replaced. If you can see a visible crack in the plastic plast-aid works well.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Oct 2011
    15
    AQUA GENIE leak x3
    Quote Originally Posted by X-PertPool
    The gasket you are referring to is behind the return face plate? Also visible cracks look down into the return?
    Thanks
    Oct 2011
    15
    AQUA GENIE leak x3
    Bump
    South Central NJ
    3,192
    Remove the 6 screws that hold the return face plate and it's gasket. The gasket is THICK and acts as a spacer too. Check for cracks.
    Use a dye pen. Also check for leaks in the liner gasket and face plate.
    Scott
    Oct 2011
    15
    AQUA GENIE leak x3
    I removed the screws inspected the gasket....perfectly fine. Keep in mind the water level has stopped directly at the bottom of the aqua genie return. So I looked inside the genie and nothing, no visible cracks no sign of leakage at all. So I filled the pool up and got out my leak die..... Again nothing perfectly still. No sign of a leak.. Again the pool leaked down to the bottom of the genie and stopped. Please help!!
    22,543
    Is there anything else at the same level that the water stopped?
    What happens if you plug the return? Does the level still drop to that level?
    Oct 2011
    15
    AQUA GENIE leak x3
    I had to order a plug for the face plate of the aqua genie. I'll try that when it arrives. Also there is a Polaris return at the same level??
    South Central NJ
    3,192
    A cut piece of a water bag, the size of the black spacer behind the return face plate and placed flush in between will work to seal the return.
    Scott
