Thread: Spa Leaking Under the Filter - Made a quick video to show it
    Video explains it:
    http://www.youtube.com/watch?v=XMddKogJfxI
    It's a Solana SX...probably 5 years old. It's been empty for a year or two and once I fill the water above the filter it starts to leak (see video for details). Any help would be appreciated.
    Doughboy 16x24' Semi inground -in progress, Hayward 210 sand filter w/ Flotec 3/4 Hp.
    South Central NJ
    3,192
    Re: Spa Leaking Under the Filter - Made a quick video to sho
    I would try a fiberglass patch to the outside. If you tried to the inside, it would likely interfere with the floating weir.
    Scott
    Owner of - PoolGuyNJ LLC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    patching on the inside will probably make a more water tight repair. But like Scott said you need to make sure you don't interfere with the weir. If you do it right though a fiberglass repair is only milimeters thick.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
