Thread: 2005 D1 Chairman II No Backlight on Topside Control
    May 2008
    SC
    47
    Control seems to work fine, but there's no backlight for the lcd display. I was wondering if there's a lightbulb that could be replaced, or if I'd need a new topside control.
    Pool: 10K Gallon Fiberglass w/ SWG and cart filter.
    Spa: 400G D1 w/ Ozone, Vision (Silver Ion).
    May 2008
    SC
    47
    Re: 2005 D1 Chairman II No Backlight on Topside Control
    I did notice that when looking from the edges, I can see 6 small led lights. But there is still no true backlight of the lcd display.
    May 2008
    SC
    47
    It's toast. Removed control and tried to take apart and dry out. Impossible. Broke it and stabbed myself several times. $315 for new control with inlay included. Also got some new brackets for the flex jout mounts, and replaced the other two inlays.
    Unfortunately, discovered that flow sensor has been leaking. Water damage inside cabinet... lots of rust on #1 pump. Think I can salvage it with some work...
