Thread: Pipe Choice
    Pipe Choice
    Contractor I'm thinking about going with runs black poly. The other runs Rigid PVC. I'm in the Northeast should this be a factor on which contractor i choose? Which do you think is the better choice.? Thanks
    Re: Pipe Choice
    Rigid PVC is better, but other differences between them could easily be more important.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Pipe Choice
    The problem with black poly is the connections are mechanical so they are more likely to leak. Pvc joints are glued so its a chemical bond which is stronger. Black poly can take more abuse though. For example striking it with a hammer won't do anything. Its really a toss up though, pvc is more common place now and so is flex pvc
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
