Thread: How do I fix this leak
    Jan 2010
    Spring Texas
    47
    Pump went dry in 108degree Texas heat. Now the outlet PVC pipe is leaking right where it comes out of pump housing. It looks like some kind of glue or epoxy was holding it together and is now cracked and squirts about a gallon of water an hour . Can I just just glue over it or does it have threads?
    Challenger pac fab ll pump
    20000 gal in ground Pentair Screenlogic 2 ez-touch 4
    Teledyne heater Compupool 40k Salt generator
    Pentair VS pump Hayward 4025 Cartridge Filter
    12 person Spa The Pool Cleaner robot
    lot of bushes and trees close to the pool
    Jan 2010
    Spring Texas
    47
    Re: How do I fix this leak
    Check out this video on YouTube:
    http://www.youtube.com/watch?v=m9ySR3vm ... ata_player
    Randy deputy iPadĀ*
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by rdeputy
    Randy deputy iPadĀ*
    That sucks, hopefully you can get it fixed. I didnt realize that you were the OP, sorry.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    You're going to have to unscrew the fitting and reseal [edit]replace[end edit] it. Check the fitting for any cracks or other damage.
    Your suction fitting is also likely to be compromised as well, so that will need to be checked.
    Support the site
    Jan 2010
    Spring Texas
    47
    So it screws in. Ok I will get it out
    Thanks
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Most likey you will need to cut and replace. The fittings could be warped
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
