Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: in ground pool with spa need help
    can anyone help, i have a in ground pool with spa that spill over. It has venturi jets but there is not enough pressure coming out ( not enough air mix). the pressure gauge say 19 psi when the spa is on. We have tried covering one of the jets to make the other jets work harder but water starts coming out the vent that's on the outside of the spa. ( think this is suppose to suck in the air to mix with the water to make pressure) We have taken out the venturi jets and run the spa and no debits come out so i don't think its blocked . Another factor could be that someone put in a 1 1/4 hp pump and motor. would just like some advise before we change it to a 2hp motor and pump.
    thanks
    debbi
    South Central NJ
    3,192
    Re: in ground pool with spa need help
    1) How many jets are in the spa?
    2) What size are the pipes, 1-1/12" or 2"?
    3) What filter do you have?
    4) Is this a liner, concrete, or fiberglass pool?
    Alas, simply putting a bigger pump might make other issues. It's not that simple and its good that you asked here first.
    Scott
    Owner of - PoolGuyNJ LLC
    okay it as 4 jets, the pipe work around filter and pump is all 1 1/2, the filter is a pentair cartridge filter ( not DE or sand) and the pool is concrete.
    thank you for help
    Debbi
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Your pool configuration sounds a lot like mine. I had a 1.5 hp pump and had to open the valves to spa and close all the returns to the pool and get the pressure up a little over 25 psi to get the jets to have bubbles in them. At 20 psi it could not pull the air in. My spa has 4 jets and 1.5 inch pvc.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    hello, thanks for that info , but i do only have the valve open to the spa and nothing else, so it is only pulling form the spa. I am a bit about the water coming out of the vent pipe outside. should there be a check valve there or something to stop this?
    thanks
    debbi
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Don't worry about the water coming out of the vent pipe. Mine does the same thing if I cover the jets.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    thats good to know
    thanks
    debbi
    South Central NJ
    3,192
    With 1-1/2" plumbing, don't go beyond a 1.5 HP pump or you would be wasting electricity.
    If water is coming out the spa venturis, either the insides are clogged or missing a piece. Can you post a pic (photobucket album, 4th option) and we might be able to figure out why. Certain Hayward spa jets are notorious for this behavior.
    Scott
    Hello,
    I've taken out all the venturi jets and i can't see any blockage.We've also tried blowing air down the outside vent where it should suck air from to see if there's a blockage but no joy there. We have loned a 1-1/2 hp pump and motor and we had more pressure but still know where like it should be. What part would you like a picture of.
    thanks
    debbi
    South Central NJ
    3,192
    I need to see what you removed.
    Scott
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Quote Originally Posted by PoolGuyNJ
    So, if you cover all the spa jets, water should not come out of the venturi air intake?
    South Central NJ
    3,192
    Sure it would. It would gush. Why would you want to do that?
    The flow to the spa jets should also draw in air via a venturi. This has the effect of increasing the pressure and water movement in the spa.
    The OP has stated, or at least this is how I am interpreting it, that this isn't happening. If the OP has the jets I think he has, I think I might know why.
    When I see a pic of what was removed, it will either confirm or refute my suspicions.
    Scott
    hi Scott,
    If its any help, when i removed the eye ball i took out the twist lock 4inches long hexagon shape tube, nothing else was in there. I'm in the understanding that this is the venturi? Also i don't get a lot of gurgling out of the vent as it should have.
    debbi
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Just out of curiosity, did you backwash your filter lately or clean it, but a smaller water pressure is experienced in my spa when my filter is not clean. Backwashing seems to cure it each time.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    there is no pressure in the spa with or without the filter
    South Central NJ
    3,192
    If what you have removed is the Hayward jet insert I suspect you have, the retention ring will have 4 tabs. Inside that ring will be a white Teflon ring that the ball shaped end would press against. There should be a second one in the jet body too. This often disappears, gets lost or is inserted backwards, more often the former.
    The two Teflon rings allow the nozzle to be held in place by pressing against the balled end of the nozzle, allowing the nozzle to be opened or closed and to change it's direction up, down, left or right. It also keeps it aligned in the jet body. Without the one in the body in place, the balled end usually covers the venturi in the jet body, allowing water to go in instead of allowing air to flow out.
    I Googled SPX0720PE2 and found a picture of them at poolpartsonline.com .
    Scott
    hi, Our parts don't look anything like them parts. i'll post a pic.
    debbi
    South Central NJ
    3,192
    Your parts look like these I'll bet:
    http://www.amazon.com/Vari-Flo-Nozzle-A ... B004VTGSI4
    and your jet body looks like this:
    http://www.hayward-pool.com/prd/In-Grou ... 0196_I.htm
    The back side is hidden from you. You removed the parts from the first link. The 4 tabbed ring has a another ring inside, or at least it's supposed to. That ring is the link I posted before. There is a second, identical one in the jet body. Reach in. If it's there, great but I'll be it isn't.
    Scott
    no not like that at all. go on to bizrate.com and its the venturi jet , gunite series. extender hex tube
    Thanks
    debbi
  20. Back To Top    #20
    South Central NJ
    3,192
    Post a pic or link to a pic please.
    Bizrate is an aggregator of different sellers. There are millions of things there.
    Scott
