Results 1 to 7 of 7
Thread: Bubbles....leak or swg working
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Just had the SWG isntalled on Thursday, the pump is primed and has no bubbles in it , however at the returns I hear a slight gurgling/bubbling and see little bubbles coming out from return and little bubbles sort of stuck around the return eye. Is this the SWG as I have read, or can there be a suction leak somewhere even though the pump is primed full?
    Thanks
    15x30 free form (10,500 gal) SWG
    Gunite, Game depth 3.5-5-4 ft, 1 hp Sta-Rite Super Max 2 speed pump, 53' Sta-Rite system 3 DE filter
    Pentair Intellibrite LED
    Pentair 125k BTU ultra temp heat pump,
    Screen Enclosure
    TF-100 Test Kit
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Bubbles....leak or swg working
    It sounds like it may be the SWCG if there are no bubbles in the pump basket. I don't think it would be a suction leak if there is no air in the basket.
    May 2011
    Sacramento, Ca
    64
    My Swg bubbles like crazy when it generating chlorine.
    30,000 gallon in ground pool, Jandy 1400 SWG, Jandy valves and controls, Sta rite cartridge filter, Just added solar panels and Starite Inellipro variable speed pump
    I spent a lot of money on drag racing, good whiskey, and expensive cigars. The rest of my money I just wasted.
    SWG produce bubbles. Sometimes they are very small and difficult to see, other times they are more obvious. If there are bubbles when the SWG is active and no bubbles when the SWG is off, then everything is normal.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Turn off the SWG for a few minutes and see if the bubbles go away. Quick-n-easy peace of mind.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    tryu cutting the pump off and feel for leaks around the pipes. I've found a few very small leaks like this. when the pump is on this very small leak sucked air and caused bubbles. also maybe its time to change your valves. these eventually wear and start sucking air. I've found 90% of the time this was the cause of the bubbles.
    I had an air leak caused by a split o-ring on the drain plug at the bottom of the pump basket. Caused all kinds of gurgling on the returns until I found it and replaced the o-ring. There was no air accumulating at the top of the pump basket but when I looked closely I could see very tiny bubbles coming up from the bottom of the pump basket and getting sucked right into the pump. This led me to check the drain plug.
    I agree with others here...see what is happening when the swg is off. If there is no change when it is off, check for leaks.
