Thread: Solar Blanket Reels
    Jun 2007
    Mesa, AZ
    Solar Blanket Reels
    Anyone have good luck with any particular type of solar blanket reels? There's literarlly dozens to choose from. I'll need one that has to span a width of 18 ft. and hold a solar blanket 32 ft in total length.
    IG, Shotcrete, PebbleTech, 30 1/2 x 13, 13000 approx. gals, 1 1/2 HP Jandy pump, 2 1/2 plumbing, cartridge filter, SWG, ozone system, PV3 in-floor pop-up cleaning, Mesa, AZ
    I bought this one ... 020,455001
    I have a 20ft wide and a 12 mil blanket. I went with an inexpensive one and is working out good.
    They made a design change from what I have. They added more support to the bottom brace which would help with sagging and stability.
    To reel the cover it takes 2 people due to the width and my over hanging coping. The edge of the blanket curls so we have to guide it on both sides. Good news it takes less than a minute to roll and I usually recruit one of my two boys (8 and 10) to help.
    When I first got the blanket I thought I could roll it up manually and the first time I tried it. I ran inside and ordered the reel. It makes using the blanket bearable.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
