Thread: Filling pump with antifreeze
    Sep 2007
    Toronto
    106
    Last year my pump seized over the winter, I managed to free it by turning the spindle by hand and it has been fine all summer. To prevent the same thing from happening, should I fill in the pump with antifreeze solution?
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Filling pump with antifreeze
    No. The area that would seize shouldn't be in contact with the water. Just drain the pump completely and leave the plugs out.
    That won't help. Seizing is almost always related to the bearings, not where the anti-freeze could go.
    Sep 2007
    Toronto
    106
    That's what I do normally and previous years it's been ok until last winter when the pump seized. Should I cover the pump with some kind of tarp to keep the snow and ice away?
    OH TWINS
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I don't recommend a plastic bag, but use something that will breath. You don't want to trap the moisture in the bearings.
