Thread: goldline controls
    goldline controls
    I have goldline controls. The generator was tested an was bad. New one installed T-CELL-5. Same unit that was inline. No reprogram required. Plug and play. Hi reading comes up then cell shuts off. ANY HELP OUT THERE!!!!!!! thanks
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: goldline controls
    High salt or high temperature?
    Welcome to TFP!
    When an AquaRite cell is wearing out, it is common for the salt reading to read lower than actual. Adding extra salt brings the salt level to above normal, allows the cell to read normal, and the SWG to continue operating correctly for a while. Because of this, it is fairly common for the pool to end up with too high a salt level. The new cell reads the high salt level correctly, and refuses to run. If this is what is happening to you, your only option is to replace water to get the salt level down.
    champion1, listen closely to what JasonLion is saying. I've had this happen. When I first got my pool, they didn't explain much to me and I added salt based on a bad cell reading. New cell wouldn't work because I had the salt level way too high. Had the water tested at Leslie's, and even though their meter was wrong, I drained some water and filled it back up with fresh and the problem went away.
    Get it tested or get a test kit for salt and see for yourself though. It's best to know what is going on in there.
    Trying to keep my house under control
    Thanks for the headsup. Will try and let you know what happend thanks agian
    Champion 1-what ended up being the problem/solution--I am having the same problem. HI Salt reading-regardless of the amount of salt in the pool. Display and two seperate testing options show 2300--but shuts off with High Salt.
