Results 1 to 8 of 8
Thread: Main power disconnect to be outside?
    Aug 2011
    Mechanicsburg, PA
    40
    I am in process of installing pool where I am responsible for electric setup.
    I am mounting my InteliTouch control box inside the basement and the equipment will be on the other side of the wall. I am reading that there should be main power disconnect accessible in the pool equipment area.
    True? Good idea?
    IG double roman vinyl 40x20. 35000 gal. 9' deep. Diving board.Pentair 400HD gas heater, ItelliFlow Variable Flow pump, 520 cartridge filter, two pentair G5 lights, IC60 SWG cell.
    Photo album: http://slava.no-ip.org/~poolpic/photo
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Main power disconnect to be outside?
    I have no idea about building codes, but it does seem like a good idea. If something goes wrong at the poolside, you want to be able to stop it now.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    yeah its code for new construction. It's also a good idea too. You might want to install a GFCI outlet near the pad too for your winterizing equipment
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2011
    Mechanicsburg, PA
    40
    Quote Originally Posted by X-PertPool
    Thank you guys. GFCI is very good idea. As far as main disconnect, can I use pull type usually found on outside AC units? or there some other type i should be using?
    It needs to be easily accessible, within sight of the equipment, and at least 5 feet from the water. It also needs to disconnect all non-grounded wires.
    A plug/socket is acceptable most places.
    Aug 2011
    Mechanicsburg, PA
    40
    How is it normally done? with a brakers?
    I only see sub pannels at the pool sites. Anybody have a picture for reference?
    There are lots of ways of doing this. When there is a sub-panel out by the equipment the main breaker in the sub-panel can usually count as a shutoff. Otherwise you can use a normal switch, or something more obvious like this one.
    Depending on the circumstances, it might be best to have the emergency cut-off switch be a simple on/off switch that goes to a main relay.
    Support the site
