In researching a pipe leak underground, I would like to disable the bottom drain in my 18x36 inground pool. Not being an hydraulic engineer, it would seem logical that the flow rate should remain the same, with just increased pressure from the two water level skimmers. If I run my Polaris a bit more each day, it should suffice in stirring up the water to let the skimmers take up the slack.
Can anyone tell me if my hypothesis is correct?
Thanks.
Thanks.
