Thread: Two Quotes need to decide
    Renovatiing 20X40
    Quote 1 $22700
    Liner, coping, 2 skimmers 4 returns, main drain, removal of 1200 sq ft concrete, pour new brushed finish, deck drainage. options( stamped 1200 extra cantelever 1500)
    Quote 2 22000
    Liner coping 2 skimmers 4 returns(no main drain) removal of concretes pour new, drainage, vermiculite sand bottom and 4 trucks of water. options (1-2 dollars per sq for stamped)
    So similar priced but second quote includes water and vermiculite although no main drain. Whats more important upgrading the sand bottom or a main drain? Have rled out wedding cake steps under liner due to concerns of wrinkles leaks etc. Thanks for any info you can provide. Anyone have cantelever or stamped in cold climates? does it hold up well?
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    30,402
    Re: Two Quotes need to decide
    How deep is your pool?
    Think 10ft has main now but seems to be debate on need for drain
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    30,402
    10 feet is very deep and I would want a main drain to assist in circulation.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    So are they giving you a regular pool bottom? Like a hard pack mix of sand, cement, and vermiculite? If so I would choose the bottom upgrade over the main drain.
    Never was a big fan of main drains, they don't really help much in collecting debris. Either way you are getting two skimmers.
    Winterizing a main drain isn't fun you have to worry about air leaks (although there is some debate whether a main drain could freeze since parts of it are so low in the ground)
    Just my opinion but I wouldn't take a main drain even if it was free.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
