Thread: New Pool Cover Coming - Closing Question
    Jun 2011
    GTA Ontario, Canada
    22
    Hi, I'm still new at pool ownership, so this might be a dumb question. I have a new mesh safety cover coming in 2 to 3 weeks. I also need to make an appointment to close my inground pool here in Toronto, Ontario. If I can't get the pool closing guys to show up on the same day the cover comes....could i close the pool and leave it uncovered for a couple of days? Or should I install the cover, then remove it for the pool closing guys, and then reinstall it? Thanks.
    33x16 (21,000 Gallons) Vinyl Inground Pool, 1/2 HP Whisperflo, Hayward Sand Filter, Pentair Mastertemp 300, 1 AquaLamp, 1 Skimmer, 1 Main Drain and 4 Return Jets...Maintained with BBB Method
    Re: New Pool Cover Coming - Closing Question
    If you're installing the cover, you should install it before the closers arrive and then remove and reinstall it when they get there to close the pool. The cover is easy to put on and remove as long as everything is installed correctly.
    The installation will take you a while if you haven't done it before, and you don't want to have to rush.
    Support the site
    Apr 2011
    Lynchburg VA
    393
    Is this a new cover or a replacement cover? I am asking because there are anchor pins that need to be installed and I am glad I didn't have to do mine....it would have never been right. If you let the pool guy close the pool w/o covering the pool, the sunlight will burn off some of your chlorine while the pool is uncovered. I would lose 2-3ppm every day. With my pool guy, when he closed my pool he put the cover on as well.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
