Thread: Wetness around spa
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Wetness around spa
    I just had my new tub put down. I've been noticing that it stays wet around the bottom of the tub. When it rains it collects around the edges and doesn't seem to evaporate since it's usually shaded down at the bottom. Should I be concerned about this? Is there anything I should do to dry the area? It's not filled with water yet and the electrical is not hooked up so it is still moveable.
    Thanks
    Here are some pictures.
    http://x-pertpool.com/tub1.jpg
    http://x-pertpool.com/tub2.jpg
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Wetness around spa
    Sounds like a good question for the tub manufacturer!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    That was my first thought. But as far as I can tell there isn't a contact number for coleman spas just a webform that requires a serial number. I'm way too lazy to do that
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
