Thread: Ph keeps rising
    Ph keeps rising
    I am using the BBB method now and I am constantly having to knock down the PH (daily). This is a new pool about 9 weeks old. Is it normal to have to lower the Ph everyday? I start at 7.4 and by the end of the day its 7.6 to 7.8, if I wait to test every other day its 7.8+. I am adding about 2 quarts a day of liquid bleach to maintain chlorine levels. The pool gets full sun and i have two kids and two labs that swim in it everyday,i know but there is no way to stop them (the dogs that is).
    Thanks in advance!
    FC 8
    CC 0
    ph 7.4
    TA 80
    CH 290
    CYA 70
    Temp 82
    15.5k pool, BBB method used, Plaster in ground pool, DE filter, full sun in Boerne, tx, NO SWG.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,029
    Re: Ph keeps rising
    Yes. Normal.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Ph keeps rising
    If this new pool is plaster, then the curing of that plaster will raise the pH significantly and require lots of acid to compensate. This will slow down over time. You are already over the worst which is in the weeks and few months right after plastering though you will notice this effect for up to a year. You will also notice the CH level rising as the plaster cures.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Ph keeps rising
    I add about 1/4 gallon every 3 days and my pool is just 1 year old. Get used to it. I do have a waterfall from my hot tub so that adds to the muriatic consumption.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    May 2011
    Montgomery, TX
    176
    Re: Ph keeps rising
    op, funny i also have a 2 month old pool, 2 kids and 2 big labs and i too go through about a gallon of ma per week trying to keep the ph down. finally got my wife to stop running the waterfall constantly and that helped some.
