Results 1 to 8 of 8
Thread: Down to Earth manual vacuum
    moze229's Avatar
    Jul 2011
    Central NC
    108
    I'm still contemplating the auto-cleaner for the pool, but I'm going to try a manual one first. The problem is, I can't really find anything out there. And, almost all of the threads here discuss auto-cleaners.
    Back in history when I was a child, at home we had a simple device. A hose connected to a pole with a cleaner end on it that you sweep the floor and walls with. Connected to the suction side. This is what I want. I can't find this anywhere for some reason. Searching for "pool cleaner" gets me a wide variety of robots and other mystical and expensive items that seem to be talking about astronomical distances rather than dollars.
    Where can I find one of these suckers and how much should I pay? Does anyone even use these anymore? If so, any recommendations?
    24' X 54" Sharkline Matrix AGP ~ 15,200 gallon
    1.5 HP Dynamo Dual Speed ran 24/7 at low speed w/250lb. SD60 Pentair Sand Filter
    Plumbed with PVC - buried.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Down to Earth manual vacuum
    What you want is a vacuum head. There are ones for vinyl and different ones for plaster. Home Depot, Lowe's, or any pool store should have them in the twenty dollar range.
    chiefwej
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    pool-school/visual_encyclopedia
    Scroll down until you get to "Cleaning Tools"
    Oct 2007
    Parkland, FL
    752
    any pool store would have them as well, although why on gods earth you would want to spend your time doing it manually is beyond me.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Thanks all! I didn't realize that I had half of the contraption already. I just needed the vacuum head. LOL. Picked up everything I needed at Lowes today.
    Quote Originally Posted by robl45
    Well robl45, it's the end of the season and I just now got our pool setup. I just wanted a way to get it clean before closing. I haven't had the chance to do research on the auto cleaners so I'm not sure which one I want yet. It's probably not a bad idea to have a vac head sitting around though just in case your auto cleaner decides to stop working or commit some type of suicide like I've been reading that many eventually do.
    The reasons for which I do the things I do is beyond many people, so don't feel left out. To be fair though, I will likely be buying an auto cleaner next year IF I can find one that meets my quizzical function vs. cost equation. Otherwise I'll be the fool vacuuming my pool manually.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Even though we own two auto vacuums ( one robot, one runs off the pump/filter) we still use the manual at least once a week. We often get just a touch if dirt/leaves in the deep end that the auto ones take forever to get. We just grap the manual one and quickly touch it up. I've also had better luck cleaning algea with the manual ones. I'm able to go as slow as I need to avoid stirring up the green stuff.
    For $20 I wouldn't not have one.
    Richard320's Avatar
    Jan 2010
    19,009
    Ten minutes vacuuming once a week while I'm outside smoking anyway versus $600 or more. That's why.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Quote Originally Posted by Richard320
    LOL that's a funny post....save 600 bucks...while smoking...bet you've smoked way more than 600 dollars worth of cigarettes!! (or cigars, or pipe tobacco, or whatever you smoke)!!..and please don't think that I am crapping on you in any way...I smoke too...if I had the dollars that I've smoked away I could have all the pool equipment I ever dreamed of, and still have enough money in the bank to just about retire!!
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
