Results 1 to 7 of 7
Thread: Newbie - Heat Pump Install Sticker shock
    Jan 2011
    Huntsville, AL
    67
    Hello everyone,
    We finally decided to put a pool in the back yard but have not yet decided on whether or not to get a heater. The PB (i learned that from you guys) quoted 6k to install a heat pump. The pool is 16x32 rectangle in North Alabama. Does that cost seem about right? I see the heaters online for 2-3k to buy and have to assume that the rest is installation? The only thing completed so far is a hole in the ground. I will try to post in the construction area later.
    Thanks!
    16 x 32 inground with Tara Liner, 1 skimmer, 3 returns,
    1HP Hayward Super Pump
    Hayward Sand Filter
    Polaris 280 w booster pump
    Hayward SWG & Aqua Plus
    k-2006 Test Kit
    Re: Newbie - Heat Pump Install Sticker shock
    $6,000.00 is high. Ask the builder how much for the heat pump (including the make and model) and how much for the installation.
    What will the installation include? Does it include electrical hookup? There will probably need to be a dedicated line run for the pool system to a sub panel if you're going to have a pump, heat pump, salt chlorinator etc.
    Support the site
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Why have you chosen a heat pump for heating your pool? Seeing you're in N AL would you be able to get much use out of it?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jan 2011
    Huntsville, AL
    67
    @ James - He did say that the cost included everything. I will get model cost and installation cost.
    @ps03 - We have not completely decided on getting the heater and pb said we still have a week or so to decide. One of the reasons that we are going back and forth is that we are just not sure how much we would use it. We could probably use it in late May and September time frames but just not sure that we would.
    Hayward Sand Filter
    k-2006 Test Kit
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by ps0303
    Why do you say this? A HP would work well in that climate.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Columbus Ohio
    178
    We have a heat pump in Ohio and we got ours for a total of 3,200 installed. the guys kind of ripping you off, our pool is a 16 x 32 and we have an aqua pro 800. It does amazing. We are very glad we got the heat pump and I do think its a great to have. I would get more info on the heat pump install, because even just to have someone run the electric it shouldnt be more then 500-600 bucks as thats what we were quoted to price it out.
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Central PA here... We are getting a Summit 8TA (140k BTU) installed for $3500. Now our electric install is $800 total, but that is for running all needed to the Hayward 100 amp panel/automation to feed the entire pad 80 from house, so not counting that in the price.
