Results 1 to 9 of 9
Thread: PVC Ball Valve Sun Exposure
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Our in-ground pool was built last winter. I noticed that one of my two PVC ball valves (red handle type), is showing significant fading of the handle after just one summer. Should I be concerned with this? I guess I could rig something to cover the valves so they're not in full sun. I also noticed that the top of the grey electrical piping and junction boxes on the house wall are turning dark brown from the sunlight.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Re: PVC Ball Valve Sun Exposure
    This happens in high UV areas like Arizona and Texas. The outside of the valve is less of a concern than the inside. The handle might break as it weakens and the valve gets old, so protecting it would help.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Here in AZ all the plumbing is painted to protect it from UV damage. It only takes a quick coat from a spray can to do the job.
    chiefwej
    Nov 2010
    Midland, Georgia
    353
    Ok, thank you for the responses. I'll see about spray painting the exposed pvc. Will any paint do? Im thinking the Krylon paint for plastics but I'm not sure if I need some specialized paint for UV protection.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Krylon is fine.
    chiefwej
    Jun 2010
    TT
    85
    How are your plastic valves holding out?
    I am also in a high uv area, but even after painting my valves, the red handles broke.
    If I had no intention to automate my valves, can anyone say whether Pegler valves (which are locally available) are suitable for use with a salt water pool?
    It looks like this : http://www.ukhps.co.uk/products/Pegler-Lever-Valve.html
    I have had good longevity with them for domestic supply, but I am unsure with the salt that's a problem.
    Otherwise, I might just have to spring for the Jandys.
    thanks.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    All my valves are Jandy type valve and they are fine. Well there are two of the ball type with the red handles on the pipes going to and from my solar panels but they have never been turned off since installation. The handles are unpainted so I'm sure they would break if I tried.
    chiefwej
    I think that the Jandy NeverLube valves would be a good choice. They come with a lifetime guarantee.
    http://www.zodiacpoolsystems.com/Produc ... alves.aspx
    Support the site
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    openpool, I'd skip the metal valves of all types, just because of the corrosion potential. Nothing is wrong with broken handles either, you just need a big pair of channel lock pliers to turn them
