Results 1 to 10 of 10
Thread: How To Hide My Equipment Pad?
    Swamp Thing's Avatar
    Nov 2010
    Eastern WA
    25
    Looking for ideas as how to conceal my pool equipment.
    Pad size = 4' X 6'.
    My thoughts for hiding the equipment:
    I'm not to concerned about the "noise" because I run the pump during the night hours (unless we have a heavy swim). My concern is protecting the equipment from the sun (and maybe because it's ugly). It receives sun from 10:30 am to 6:00 pm and the summer highs can reach 100 degrees. I recently went through all the connections stopping even the smallest drips/leaks and painted the PVC. I want easy dis-assembly of the structure in order to provide access to all components for easy repair/maintenance. Lastly I think proper airflow is in order to keep the pump motor cool.
    Left to Right:
    Patio area.
    Filter (duh).
    Blue lockers where the kids store goggles, flippers and such.
    Living room window.
    You can see the setup is right off the patio near the shallow end. There is a gate in the distance that we prefer guests use when coming over. I plan on making a paved path through the grass leading to the pool area.
    In-ground Gunite 16' X 40'
    Tagelus TA/60 Sand Filter
    A.O. Smith 1 HP Motor
    Sta-Rite Dura-Glas II Pump
    Pentair #320 Inline Chlorinator
    Intermatic Mechanical Timer
    May 2011
    Orange County, CA
    696
    Re: How To Hide My Equipment Pad?
    I'd build a 3 sided box with sloping lid using 2x4's for the frame and covered with similar paneling and 1x4 trim as the house, then paint to match the house (including white trim). The lid would be sloping (sort of like the lockers) to move rain away from the box. And then I'd add small casters on the bottom so that I could easily roll it away (pull out from house) for servicing. The box would be rolled into place flush with the wall, but below the pump timer box. You may have to move the other j-box to make this work. Since the box would be three sided, there would still be enough air circulation, and since the box would not be completely flush with the ground, cool air would circulate and vent at the top at the back of the box. The hinged lid would allow for simple servicing without having to move the box away from the wall.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Nov 2010
    Eastern WA
    25
    The box I've thought of but the addition of casters is a great idea!
    May 2011
    Orange County, CA
    696
    Great! Let's see what it looks like when you build it. Please post some pics.
    Ft Lauderdale, Florida
    1,455
    How about a Rubbermaid storage shed with a sliding lid. http://www.rubbermaid.com/Category/Page ... D=RP091380
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Nov 2010
    Eastern WA
    25
    Quote Originally Posted by Poolsean
    I've looked at those but never found one big enough(Until now) ...Thanks for the link!
    Apr 2010
    Buckeye, AZ 85326
    619
    Looks like they've got you covered. I just wanted to add that I really like the locker idea....pretty slick.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Nov 2010
    Eastern WA
    25
    This post is long over due...I thought I updated it.
    Here's what I came up with...The boards are spaced with large gaps for air flow.
    There are 2 hinged boards for access to valves and such for start up or vacuuming.
    This board has a spring to keep the wind from opening it.
    Plenty of workspace.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Looks good, I am not sure how much exposure protection it really offers though
    Nov 2010
    Eastern WA
    25
    Quote Originally Posted by Isaac-1
    Thanks...The equipment is completely shaded which was my primary concern. During the winter I disassemble most of the equipment and store it in the pool house. Not much rain protection but it's sure nicer to look at...Plus it keeps little ones from being near the hot motor!
