Thread: Calcium Hardness
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Calcium Hardness
    Would I be correct to assume that calcium hardness is similiar to cya in respect that it will not get lower because the calcium does not evaporate therefore it will tend to rise eventhough the fill water has a CH level of 250?
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Calcium Hardness
    Yes.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Thanks, I figured that would be correct.
    How do I reduce hardness?
    30,424
    A partial drain and refill (with less hard water) is about the only practical way.
