Thread: Pentair easytouch overide/bypass?
    Is there any type of bypass or override on the Pentair Easytouch system? I've tried to reset everything and still no power to the outside control panel, no display and nothing running. So until I can get a repair person out is there anyway I can get the equipment running? Maybe some jumpers or something I can set to run pump etc? Systems been down two days now.
    Re: Pentair easytouch overide/bypass?
    Welcome to TFP!
    If you can't get the control panel to work at all, the only work around is to rewire things inside the panel to bypass the relays. Before you do that, make extra sure there is power getting to the main control box (perhaps a breaker tripped on the main panel inside) and that the control electronics fuse hasn't blown.
    Where is the control electronic fuse located?
    I already reset the breaker in the garage with no change.
