Thread: Beaded steps VS Rod Pockets
    Jul 2009
    Fort Wayne, IN
    392
    Which one is better and how do they work and install? Thanks in advance
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Beaded steps VS Rod Pockets
    beaded steps? You mean like the white fiberglass/plastic steps with the gasket? I personally hate vinyl covered steps with the rod pockets. Installation is harder but I dislike them more so because the pool vinyl isn't the ideal pool step material in my eyes. The vinyl covered steps always have gaps and if you ever get a leak there it will loose water quickly. The top vinyl steps end up shrinking and getting tight which isn't good for an area you are going to be walking on.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    I think that by "beaded steps" he means covered with vinyl liner, and held in place by a bead (tab) on the back side of each step (I think in the corner where each tread meets the next riser going up), which fits into a bead receiver incorporated into the step support system behind it.
    I can't seem to find much info/pictures on the internet thoroughly describing these two methods on steps either. If anyone on here has some it would be great to see them!
    Are you recommending the plastic steps with gasket? I've seen some people vinyl over them when they eventually crack or leak, and assumed these were less desirable; but I don't know for sure...
    edit: just found this on the beaded step:
    http://www.youtube.com/user/tkennedy74# ... J0Z7qaiKj0
    16 x 32 Vinyl Inground Rectangle
    16,800 gallons
    SE Pennsylvania
    Brand new pool and owner.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I've only seen the rod pocket type. Anyways,yes I prefer the fiberglass / plastic steps with a gasket. It is possible for them to crack but it's usually the pool builders fault for not properly supporting the steps from underneath with back fill. Regardless I've fixed cracks in the steps before with fiberglass and painted them white with epoxy paint. The steps that crack usually feel very hollow, its all about supporting the steps. Even with that being said I much prefer those style steps to vinyl covered.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
