Thread: Test Kit Question
    Test Kit Question
    What kit is the most user friendly and provides the most accurate numbers?
    Looking at the DPD OR FAS-DPD
    And before closing your pool should the water temp be at a certain temp?
    142OO Gallon
    Cartridge Filter
    AG
    1 1/2 HP Pump
    Charleston SC
    Mar 2009
    Huntsville, AL
    156
    Re: Test Kit Question
    Most people here will recommend the FAS-DPD test kit. There is an article comparing two popular kits in the Pool School - click the Pool School link at the top right of the page and scroll down to the "Test Kits Compared" article under the Pool Chemistry heading.
    As far a closing temperature for the pool -- 60 degrees seems to be recommended often (both for closing and opening).
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    User friendly and accurate don't really match up. Test strips are the most friendly, and by far the least accurate. Accuracy is much more important, go with FAS-DPD, which is the most accurate/precise.
    I like to wait till the water is 50 degrees or colder before closing. 60 or below is normally fine, but waiting a little longer improves your odds of having an algae free spring.
    As always you come through! Thanks
    I will read the article memtioned above and Jason, I agree Accuracy is the word of the day.
    142OO Gallon
    Cartridge Filter
    AG
    1 1/2 HP Pump
    Charleston SC
    FAS-DPD is the way to go. When you have a problem you need to accurately test high FC levels. Everythingis simple after you do it a few times.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
