Thread: Best Practices for attaching new Jandy ePump
    I am replacing my old pump with a new Jandy ePump. The new pump has two nice threaded tail piece interfaces and I was just wondering if there were any "Best Practices" for connecting the pump to the existing plumbing other than solvent weld accordingly?
    Above Ground Pool, 15x24 Oval - 10,500 Gal,
    Hayward Sand Filter - 150lbs, 1.5HP pump
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Best Practices for attaching new Jandy ePump
    If you haven't done this already, I would use pipe dope on the threads (not glue of any kind) and would use unions on the inlet and outlet sides, so the pump can be easily removed if need be.
    Yes, unions are a good idea. Thanks for the advice.
