Thread: hayward heat pump fan motor failure
    Murfreesboro, TN
    92
    I have a 3 yo hayward heat pump model HP21002. It has been flawless and well built. In fact, it is our second one of this type, as we had a pool at our old house that used this heater when it was built by EUS.
    It seems the fan motor is going bad. the fan is dragging on start up or not spinning at all. if you give it a push with a long screwdriver, it will spin on up and run fine. I found all this after a "LP" fault code.
    Any chance easy fix without replacing motor?
    Is this part user changeable? Do i need a Hayward motor? (part # hpx11023564) or could i go to local electric motor company and use different (less expensive) motor?
    average price for Hayward is $150 new.
    Thoughts?
    Thanks
    Cal
    Cal C.
    20k ig vl, hayward 2sp Tristar, hayward pro series sand filter, ecommand 4 with aqua connect, hayward heat pump, polaris 280 cleaner, TF-100.
    Dec 2009
    Central Massachusetts
    2,690
    Re: hayward heat pump fan motor failure
    There may be a start capacitor on the fan motor. If thats bad, it will cause the fan motor to act just as you described. I had the same type of thing happen on my Aquacomfort. Fan motor was slow/dragging; i could use a screw driver to push it along to start it spinning. It ended up being the start capacitor and not the motor itself. I'm not saying this is whats causing your issue, but it might be a place to start looking.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Murfreesboro, TN
    92
    thx!
    did you fix it yourself?
    any info appreciated.
    Cal C.
    Murfreesboro, TN
    92
    there is a fan RUN capacitor on the board, but no fan START capacitor that i can see.
    outside the limit of my knowledge.
    anybody?
    Cal C.
    Murfreesboro, TN
    92
    i guess smoke coming out of fan motor is bad........
    Cal C.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, I bet so. Sorry nobody got back to you; I don't think it's a problem many people deal with.
