Thread: Best way to remove DE from pool water?
    A new client of mine had holes in her DE grids, and as such, it has been putting DE back into the pool. This has been ongoing for several months (yes, months!). I took the pool on yesterday, replaced the broken grids, and now have to get the DE out of the pool.
    The pool is FULL of DE. It's very cloudy. Even after 48 hours of the filter being switched off completely it was still cloudy.
    My initial thought is to let the filter run 24/7 and allow the circulation to put the DE back into the filter, and then vacuum the remaining DE from the floor.
    I'd be very interested in hearing the thoughts of others.
    Thank you.
    Apr 2011
    Lynchburg VA
    393
    Re: Best way to remove DE from pool water?
    That's the way I would do it. I would think that the filter would catch the DE.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2011
    St. Paul, MN
    244
    I agree with you and BadOleRoss. In addition, if your client has a automatic pool cleaner I would run that frequently, if not 24/7 as well. That should help to pull the DE off the floor and to either the main drain or the skimmers.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
