Thread: Is it normal
    Is it normal
    Partial drain my pool due to high CYA# 80
    Had what looked like MA on the bottom of my pool so I schoked with clorox bleach 6% to 40ppm
    Been vacumming to waste and the brown stuff still appears
    checked my PH level and now its at 8
    At what point can I add the Muric to bring down my PH
    I will no longer use the pucks and wonder should I be adding bleach daily or let the FC level come down before doing so.
    I hope when I get home today the brown stuff on the bottom of the pool is gone, got a bad feeling though.....its been kicking my but. Its been suggested to FLOCK but dont want to do this if not needed. Oh well keep battleing the brown stuff ( the brown stuff is not slimy, really fine and can brush easily by hand when waved close to it) any suggestions would be greatly appeciated. You guys rock on here, so much better than the pool store crews!!!!!!!!!!!!
    142OO Gallon
    Cartridge Filter
    AG
    1 1/2 HP Pump
    Charleston SC
    Mar 2010
    Spring, TX
    1,082
    Re: Is it normal
    If you are done shocking you can let it come down on its own and will just need to check the FC daily. Once it gets low then you can start to add bleach at that time. Once FC is under 10 you can check pH level. pH test with FC over 10 will yield incorrect results.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    30,414
    Re: Is it normal
    The "brown stuff" is likely dead algae. I can't tell from your post if your FC is still high. Please post a complete set of test results and we can advise you much better.
    Re: Is it normal
    Will post #'s tonight......thanks
    142OO Gallon
    Cartridge Filter
    AG
    1 1/2 HP Pump
    Charleston SC
