Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: What pool temp is ok with you?
    htownjeeper's Avatar
    Aug 2011
    Nassau Bay, TX
    199
    Since this is my first year with a pool, I'm just curious at what point does everyone go "Oh **** no, that's too cold!"?
    22,000 inground Fiberglass
    DE Filter Pentair FNSP 48
    Century Centurion 1.0 HP 1.25 S.F. 3450 RPM
    Jul 2011
    Central Califorina
    208
    Re: What pool temp is ok with you?
    With my hot tub I will use the pool for a cold plunge untill the water temp drops below mid 60's.
    Comfortable swim temps with a hot tub to slip into would be mid to low 70'S.
    This is my first year with a pool too. I just put up a 4x20 fafco solar panel for my 2000 gallon ABP in California. I hope to be extend the swim season till November.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    Dec 2009
    Central Massachusetts
    2,690
    Middle of summer, about 83. This time of year and in the early May time frame, about 87-88
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mar 2010
    Spring, TX
    1,082
    80+ for me. But has a lot to do with outside temps as well.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    82 degrees, otherwise the familial users start to gripe at the operator, I.e., me.
    20k gal. 36' In ground Med. Blue plaster, two-speed EcoPump EP6, Pentair 3.14 sq. Ft. Sand w/zeosand, Spectralight SL 500, RayPak 2100 heater, Polaris 360,GE Timer 15087, Borates 80 ppm.
    Apr 2011
    Lynchburg VA
    393
    I like it at about 85! If I am planning an evening swim bump it up to 87/88
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    84 is about as low as I'll go.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Aug 2011
    Nassau Bay, TX
    199
    I'm still hanging tough at 87 consistently with bumps up to 90. I guess I have a few more weeks left?
    Jun 2011
    Cape Girardeau, Mo
    125
    No lower than 84 for us once it hits 80 i am just waiting for it to hit 60 to close.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    84-86 is our preferred temp range. With a solar system and a cover we can keep it in range from mid April until about Thanksgiving.
    chiefwej
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    84+
    82 is nice on one of the humid hundred degree days we get. 86 is nice most of the rest of the summer.
    Maryland
    18000 gallon plaster pool, Pentair Triton II sand filter, Purex Triton Minimax Plus 300 gas heater, 1.0 HP two-speed Pentair Superflo, Polaris 380
    Caldera Marino hot tub, 360 gallon
    Jun 2007
    New Jersey
    653
    If it goes over 84°, I start pumping in 55° well water. Ideal for me is 74°-78°. If the day is hot enough to work up a sweat, I'm good down to about 68°. I deliberately did not install a heater, so the women can't make me use it.
    I believe racing pools are supposed to be kept at 69-72°. I like to swim for exercise and after exercise or physical work. An 80° pool is useless on a hot day.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    I have been swimming in the last week since we finally got our pool set up, the season is still young for us here in Australia, so the first time it was around 62. I had to fetch out some stuff that had fallen in though lol. Yesterday I went swimming for fun at 68, it was chilly but bearable. I'll have to see how the season goes and find my perfect temperature, but off my trial runs I think around 77 would be nice.
    8496.55 Gallon Oval Above Ground Pool, 1 1/4 HP Onga Pump, Onga Sand Filter, Solar heating, and a Creepy Crawly :)
    Mar 2011
    Houston, Texas
    413
    I like mid-80s and even up to 88 is ok. Yesterday my pool was 85 at 5:00 pm and this morning it is 79. The next couple of weeks until the first real cold front blows through will be some of the best swimming days of the year here in Houston.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Feb 2011
    Petaluma, Ca
    665
    My 1st swim on memorial day was @ 68 deg, way too cold for a pool but feels good if your in a Sierra lake. Its refreshing but you cant stay in long. Now with the solar heating the pool temp hit 87 deg yesterday, outside temp approx 90 deg. As has been mentioned cooler is prob better if your exercising but for hanging out 85 / 87deg is perfect for me.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,071
    90 to 92 degrees. We do most of our swimming at night.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    We are at 57 today...I jumped in last night to rinse from the hot tub...not exactly sure of the temp, it was cold, but refreshing. Normally, I would say ~65 but the hottub helps.
    Jul 2011
    Central Califorina
    208
    +1 on the hot tub. I will look for any reason to get in the water. Any temp between 108 and 58 would be fine for me. Being able to switch back and forth between the temperature extremes really cleanses the body and soul. Puts me in a zen mindset.
    Taylor K-2006
  20. Back To Top    #20
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    In high school we swam in an outdoor heated pool at the YMCA for practice.
    During the winter they kept it about 78 for us, and that was fine.
    One day some prankster took down the "heater is broken do not swim sign" and we all went out and jumped in. The water was in the low 50-high 40 range. We tended to sprint from the locker rooms to the pool when it was cold and just jump in and go. That day we LEVITATED out of the water as soon as we hit it. One girl actually developed heart palpitations from the shock and had to go to the emergency room.
    Anyway, I like anything from 72 up. It really depends on the air temp as to what I find comfortable to just hang out in though.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
