Thread: FS: Hayward H400IDL heater parts
    I have a used heater as stated above, the heater core and blower are both not good. I decided to replace with a new heater so if anyone needs any parts make me an offer and loacation and I will get back to you. I am located in Las Vegas.
    Thanks
    -9000 Plaster IGP and attached spa with 4 jets , Hayward H400IDL NG heater, Hayward swimclear 4025 cart filter, Hayward superII 2hp pump, Goldline controls ps-8 controler with T-cell 15, Caretaker 99 in-floor cleaner and polaris in-ground leafetrapper.
    Re: FS: Hayward H400IDL heater parts
    Hello, I have a Hayward H-series pool heater h400IDL. Our control panel went out and I would like to know if yours works. We are located in Henderson, NV. If it is in working condition, would you take $100?
    Byronn
    12' x 18' x 54" AG Sharkline, 5,800 gallons, Waterway Millenium 27" 250 lb. sand filter, 2HP motor @ 18/55 GPM, timer running filter on high 6 hrs/day, Rainbow Lifeguard #320 auto 3" puck feeder, location: New Orleans, LA
    Yes, I will, I can bring it by this week if you would like. PM me your number, I can bring it by sun, tue, wed or Thursday. I am a little limited for time on sun but maybe we can make it work.
    I took most of the heater the scrap yard today but I kept the gas valve and burner assembly, both vacuum valves, wire harness and manifold. Let me know if anyone needs any of these parts.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I know this is an older post, but I was wondering if you still have any parts. I think I may need a manifold bypass assembly and header gasket. I haven't taken it apart yet to see though.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
