Thread: polaris booster pump making noise
    Apr 2011
    Houston, TX, USA
    105
    hey guys,
    in this thread (member23638-topics.html) i talked about coming back from vacation and my regular pump was not working (capacitor died). Well, it also had a side-effect. now that i got that pump running fine, i tried to start my polaris booster pump (PB4) today.
    The booster pump starts, water is flowing fine, and the polaris went around the pool to do his work gathering leaves. However, the pump is making a ton of noise. it is a screeching like sound that is constant and did not let go in the 30 minutes i had polaris running.
    I turned it off after that to prevent further damage. Any ideas on what might be wrong? COuld it be that something in the impeller melted because (and this is a fact) polaris run for a few days without water pressure coming from the regular pump?
    14500 gallon plaster pool (replastered in May 2009) : 32ft.L x 4ft.D x 14ft.W
    Pentair FNS Plus 48 sqft DE filter
    Polaris 280 at 2hrs per day (retired now) & Aquabot T-Jet Turbo used as needed
    Circupool RJ30 SWG set at 80% output & Pentair SuperFlo 1hp 2speed running 6-8 hrs/day in the summer
    South Central NJ
    3,192
    Re: polaris booster pump making noise
    The screeching is likely bearings. Check for a leak where the shaft meets the wet end. I will bet the seal set is shot and that that let water spray at the motor.
    Scott
    Owner of - PoolGuyNJ LLC
    Apr 2011
    Houston, TX, USA
    105
    I will do that. However, i don't see any water spraying at the motor (the rotary thingi is visible and i don't see water around it)
    Apr 2011
    Houston, TX, USA
    105
    thank you as well!!!!
