Thread: Recommended paint for gunnite pool
    I have a gunnite pool that is in need of repainting this winter. Does anyone have suggestions on the best paint (type and brand) to use?
    Thanks.
    45K gallon IG old (1950s) concrete pool (white plaster)
    Rectangular 20' by 40' with 12' deep end
    one skimmer in deep, two returns in shallow
    1 HP Hayward pump
    Hayward Pro Series 300 lb sand filter
    Aquabot T4
    TF100 Test Kit
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: Recommended paint for gunnite pool
    Yeah, I've got a tip: Sau-Sea paint. Check out their web site at http://www.sausea.com/
    I used their paint and had no problems. My prep work wasn't the best in the world, either. It was a DIY job and a lot cheaper, quicker, and easier than a re-plaster job.
    But stick around TFP for a few days. I bet you'll get quite a few tips bacause there are lots of folks with some very strong opinions on the pros and cons of painting. Go to school on those tips and make an informed decision.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Paint is almost never worth using below the water line. Even the best paints don't last that long, so that by the time you have re-painted several times you would have saved money and had far less hassle by getting plaster instead.
    Swamp Thing's Avatar
    Nov 2010
    Eastern WA
    25
    Sorry...New to pool ownership.
    So plaster is colored?
    In-ground Gunite 16' X 40'
    Tagelus TA/60 Sand Filter
    A.O. Smith 1 HP Motor
    Sta-Rite Dura-Glas II Pump
    Pentair #320 Inline Chlorinator
    Intermatic Mechanical Timer
    I thought that paint protects the plaster? I assume that replastering is not a DIY job? Does the plaster come tinted? Thanks.
    1 HP Hayward pump
    Aquabot T4
    TF100 Test Kit
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    You can get all different types of colored plaster. Here's just one link I found: http://www.atglabs.net/ourcolors.html
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
