Thread: Closing pool with loop loc cover
    Hi all,
    My first year that I'll be closing my IG pool on my own. Had local companies close it the first 2 years but now I'm going solo after learning tricks of the trade. One item I forgot to recall is how to put the loop loc cover back on. I feel like they mentioned starting from the sides first or the ends first, I forget! What is the proper procedure? Also, I remember the mesh cover has a darker side and a lighter side. Which side should be up?
    Thanks!
    3rd yr pool owner, 16x36 oval IG,Sand Filter, Vinyl liner, 3/4 HP hayward pump,loop loc cover
    Apr 2011
    Lynchburg VA
    393
    Re: Closing pool with loop loc cover
    I seem to recall the top side is a little darker and has a slightly shiny finish compared to the bottom. It's pretty clear which side is up when you start fooling with the cover. When I install mine, I unfold it so I can attach the hooks at one end of the pool and then I will attach the cover about half way up each side at one of the points and then the other end. Once I get it in place I attach the remaining straps. There really is not set way to do it as long as you are not having to fish your cover off the bottom of the pool.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    I have a vinyl lined pool. Should I lower the water to loop loc recommended level of 15 to 18 inches below the top of the pool ? Been reading that it is bad for a vinyl liner.
    21000 gal vinyl lined in ground
    36 sq. ft. DE filter with Hayward 1.5hp VSP
    SWG chlorine
    Massachusetts
    New Brunswick Canada
    819
    It shouldnt bother the liner, I have a safety cover as well, the cover needs the support of the water over winter, lower the water and you could end up with torn cover or pulled out plug where they screw into your deck. I lower my water just past the skimmer then cover, if alot of snow an rain result over winter, the water just runs over the sides, or if mild out, I put a submersible pump in and drain.
