- Jan 26, 2011
- 40
Actually, my first experiment will be done in a 5 gallon bucket. Wanna understand this a little bit better before I commit the entire pool to it.
draythomp said:Rickster, nice to have someone else looking into this.
Maybe we could dissolve the oxalic acid in water and pour it into the skimmer letting the precipitate get caught mostly in the filter. Filter for a day and then clean the filters??
A flocculant such as OMNI Liquid Floc Plus might work better for this situation than a clarifier, but I'm not sure and you'd have to experiment to find out.draythomp said:Here's the problem I suspect. We get the precipitate and filter some of it out, then we put back chlorine to keep the pool from going green and it wipes out the oxalate putting the Ca back into the pool. We gain some lowering of the CH, but not much because we couldn't filter all the precipitate out. So, what do we know about flocculants? Maybe we could dissolve the oxalic acid in water and pour it into the skimmer letting the precipitate get caught mostly in the filter. Filter for a day and then clean the filters??
One thing that chem geek said kind of bothers me. If we can only get rid of roughly equal weight of the calcium carbonate and a pound of oxalic will only give us 10ppm reduction. So, to go from 900 down to 250 or so would be a whole lot of pounds. Chem geek, did I hear you correctly??
draythomp said:OK, so I'm driving everyone nuts with this.....sorry.
I just spent some time looking at the water softener idea...
- Running salty water through a standard water softener (Strong Acid Cation, SAC, ion exchange resin) will not be as effective. It will still remove some calcium, but not nearly as efficiently and it will saturate and require recharging more frequently (you would need a more concentrated salt solution during regeneration to get more capacity and reduce calcium leakage). There are Weak Acid Cation (WAC) resins designed to work with high salt waters, but they require hydrochloric acid and then sodium hydroxide for regeneration.RickstersPool said:-Would a water softener work with the salt water in a SWG pool, or will it kill the ion exchange?
-Will the chlorine kill the softener (I've seen "chlorine resistant" resin).
-Will sodium buildup be a problem? Will it magically combine with chlorine to form salt :?
