Solar heater with GL 235 and GVA 24
Sep 20, 2011
1
Hello all
Recently i brought a house and that house has a pool, I have solar heater, looks like sensor is not working.
Right now in GL 235 i have selected manual off and water is flowing from pump to roof mounted solar heater and in pool.
i don’t want to flow water towards solar heater till will change the sensor and make it function so how can i bypass solar heater and water can flow from pump to pool and vice versa.
I tried to read GA 24 manual but did not get more idea... i will really appreciate your help.
Thanks
A picture of your valving will help a lot, but the solar should have either two 2-way valves or a 3-way valve that diverts the water through the heater. If it's two 2-ways you close the one going to the panels and open the bypass valve. If it has a 3-way valve you position the valve so that the flow to the panels is blocked and the bypass is open.
There should be a switch on the valve to reverse operation in case the actuator isn't operating it correctly. Switching it will turn the valve the opposite direction that it is now.
