Results 1 to 9 of 9
Thread: In the swim doesn't have a pool cover in my size
    My pool is 18x34, in the swim has a cover for a 18x33 pool, the cover itself is 22x37, so that will only leave me 1.5 feet on each end. Is that just too tight?
    Only other option is for a 24x41 pool, the cover itself is 25x45, which will leave 3.5 ft on each side, and 6ft on the ends, that sounds like too much.
    I could probably order a custom size, but I'd really like it by this weekend. So if I can't get one from them, I will just go to a pool shop the next town over and get what I could get.
    Re: In the swim doesn't have a pool cover in my size
    I'm no expert but I believe the 18x33 and 18x34 are the same. Some one else can probably confirm this better.
    Get the bigger cover and fold it under.
    Note: I am assuming that this is a waterbag cover and not a safety cover.
    Support the site
    Quote Originally Posted by JamesW
    Darn, I was afraid you would say that. I don't want to spend that much more, lol! I'll keep shopping.
    And it's a wintercover, not a safety cover.
    Quote Originally Posted by Candi
    I still think if it is for an above ground pool without a deck around pool it is the same. I see them as listed as both sizes on different sites. http://www.poolsupplies.com/covers/wint ... shapes.asp (It is actually 22x38 instead of 22x37 that In the Swim has it listed)
    Now if you have a deck around the pool and plan on water bags then maybe go bigger. My pool is 18x33 with full deck and I went with a 18x36 inground cover with water bags and hated it. Just ordered this http://www.arcticbluecovers.com/product ... /223/ci/70 for this year
    They offer it with attachments to wood decks as well.
    I didn't see that this was an above ground pool. My advice was intended for an in-ground pool or an above ground with a full flush deck. If it does not have a full deck, then you probably will want to get a cover that fits better so that it looks nice.
    Support the site
    Oh, interesting on the sizes. But even on the site you linked, some are listed as 33 and some as 33/34, and I would think I would depend on the manufacturer of the cover??? I'm so confused.
    We have a deck but have allowed room for the cover to go under the deck and around the pool, as if the deck wasn't there.
    The Poolsupplies cover is 1 foot longer so it can handle a 33 ft or 34 ft pool. That is why it says 18x33/34 in the discription, because it is capable of handling both sizes. But honestly both have enough coverage if using the cable system to sinch the cover to pool. Going with a larger cover only makes sense if you are going to have it on top of the deck and held down with water bags. Pros if I am telling her wrong please chime in.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    How much water you drain will affect things as well, if you drain alot then 1.5 ' will be pushing it.
    I have a 20' pool and I ended up going with a 24' cover instead of 21', I don't regret it, it's got some extra room but big deal. I drained it down about 8" below the skimmer as we get a lot of rain and melting snow before the deep freeze sets in.
