Thread: Add Borates Before Closing?
    Sep 2011
    Nanty Glo, PA
    55
    It's about time to close our pool for the season (my first closing). I had intended to add 50ppm of borates (by using the borax & muriatic acid method), but just didn't get around to it. I was thinking the algistatic effects of having borates added would help keep the pool cleaner through the winter until I re-open.
    Should I go ahead and add? Or just save it for next season when I re-open? I understand that I will likely have to test the borates level and add more come Spring due to draining for closing and refilling and I am fine with that. Water temp is around 70 now if that makes any difference.
    Garry
    Above-Ground Pool 24' x 52" (13,500 gal)
    Installed May 2011
    Hayward 1HP Power-Flo Pump. Hayward 150lb Sand Filter, Main drain
    Plumbed with Flexible PVC & Fittings June 2013, Modified Slotted Return Jet for Increased Circulation (2014)
    Feb 2008
    Denton, TX
    5,061
    Re: Add Borates Before Closing?
    I'd just wait until you open in the spring.
    30,432
    +1 for waiting 'til Spring
    Sep 2011
    Nanty Glo, PA
    55
    Alright then, Spring it is.
    Garry
    Installed May 2011
