Thread: Greasing the valves ??
    Dec 2007
    South Carolina
    2
    Hi all... and it's so great to find this site!! I am a newbie to it and I gotta say.... THANKS!! I was a Ben Powell fan, but bless his heart (old Southern term), he can't seem to keep his site up. This one is great.
    Here's my question. I have several, for a lack of a better word, switches/diverters that switch the water from main drain to skimmer, also returns to pool seat spa. These have a little black knob that as you tighten it, it greases the valves (there's the work I needed). I am wondering since mine are at the end of the threads, how do you regrease these? There seems to be a plate of some sort there, but no grease fitting. Is this some sort of cup that comes out and you repack it??
    Thanks for any help. I am sure to have a dozen more questions in the future.
    Rock G in SC
    Shannon
    18,000 gallon octagon vinyl liner pool. Sand filter. Main drain closed.
    30,419
    Hey, Rock,
    I can't get a mental picture of the knobs you're speaking of. A picture would be great, if you can do it. (Others may not be as obtuse as me and know exactly what you're talking about)
    Meanwhile, welcome!......you'll find this a tremendous site.
    Guest
    Sounds like you have a Jandy valve with the grease cup on the side. You are supposed to unscrew it and lube it with a high quality silicone or teflon grease made for pool use. I like the Aladdin Magic Lube which is teflon based. Magic Lube II is silicone. Either one is fine to use (or any other brand made for pool equipment use). The grease fitting should be refilled every 3-6 months. Here are the instructions from Jandy:
    This section does not apply to Jandy NeverLube
    Valves and non-positive seal valves. NeverLube
    Valves and non-positive seal valves can be identified
    by the absence of a grease cap. NeverLube Valves can
    also be identified by the name "NeverLube" on the
    handle.
    The following direction are for lubricating the valve
    diverter seals.
    1. Turn off all pool/spa equipment.
    2. Rotate valve handle so the OFF on the handle is
    over the word GREASE on the valve body.
    3. Unscrew (counterclockwise) and remove the
    black cap of the grease fitting.
    4. Fill cap with lubricant (Jandy Lube).
    5. Replace cap on fitting and turn in (clockwise)
    until all of the lubricant has been forced into the
    valve.
    6. Move the handle from side to side to spread
    the lubricant across the seal.
    7. Reset the valve handle to its original position
    and start equipment.
    Once a year the valve should be disassembled
    and the O-ring and valve body inspected for damage.
    Thoroughly lubricate the square seal and the O-ring.
    Reassemble the valve.
    Dec 2007
    South Carolina
    2
    That's it
    Thanks so much for the help. I think I understand how it works now. I wasn't sure if you used a special gun to lube or not, but I think I will buy some grease and see how it goes. There is a metal "fitting?" there, so maybe the cap forces the grease through the fitting. I took pictures today of it for others to see what I'm talking about, but I am at work right now and can't post.
    Thanks again for the help.... what a great site.... AND good helpful people.
    Rock G in SC
    Shannon
