Results 1 to 8 of 8
Thread: why bother clearing the algae
    Jul 2009
    Massachusetts
    188
    so, i waited too long to schedule a pool closing and due to various reasons, we haven't gotten around to chlorinating the pool. Right now, it's green.. very green.. and i'm wondering what harm there is to not bringing it to shock level before we close. The reason i ask is because ever since we've had this pool (2.5 yrs) we've opened it to a green swamp and i wonder how much worse it would be if it's already green now.
    Also, the pool company who will be closing it for us said they add pool shock before closing and then for add'l $45, they'll add pH buffer, metal (something, i can't read my handwriting), non chlorine shock and something to help with alkalinity. Do I need all that? again, just wondering how much worse my swamp would really get if I didn't get all that.
    FYI, we have a safety cover, so it's totally porous and I guess there's no way of avoiding algae anyways with a cover like this?
    Thanks
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: why bother clearing the algae
    In your case, I'd say, save your money. Adjust pH, then button things up.
    Armed with the knowledge in Pool School, and a decent test kit, you'll be able to open in a week or so next spring.
    Jun 2011
    Cape Girardeau, Mo
    125
    I agree with Richard,, and no ,no no you don't need that stuff they are trying to sell you you will just waste $45.00..
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Feb 2008
    Denton, TX
    5,061
    I agree with agreeing with Richard.
    Jul 2009
    Massachusetts
    188
    ok, thanks.. i figure that a swamp before i close and a swamp after i close are just swamps all the same..
    i am curious if it's possible to avoid a swamp when i open though..it's never been done before at our house..
    btw, i noticed in a few posts that the 'officials' .. ie jason, etc .. recommend adding algaecide.. when we close this year, we'll just be getting shock.. should i have the pool guy add that before we close?
    thanks again..
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by patplh
    You can avoid a swamp when you open by closing late and opening early and following the shock/close method in Pool School;HOWEVER, it will not happen thiscoming season for you as you are closing 'green'.
    Polyquat 60 is recommended for a 'clean' close as it will help prevent algae, but since you already have algae, no since adding algaecide. Save your $ for spring opening .
    If possible, could you post your CYA level at closing and again at opening?
    thanks again..
    You're done SLAMing when:
    One of the guys from the pool company that installed our pool came out to replace the flow switch under warranty. He told us that 62F is the magic water temp. Open the pool before the water temp reaches 62F, and close it after it drops below 62F, and you'll eliminate the algae problem. Our pool was installed late summer '09, and so far we've never had an algae bloom. There were several people around us that have a mustard algae bloom this spring, it never affected us.
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    There is no single magic temperature. There are rare reports of algae growing in frozen-over pools though such growth is very, very slow. I usually recommend closing the pool when the water is as cold as possible, though 50ºF is probably quite reasonable, and to open as early as possible. One can certainly pick a different temperature, but the risk is higher at a higher temperature. The colder the temperature the slower algae grows and the longer chlorine lasts if not exposed to sunlight.
