Results 1 to 12 of 12
Thread: Lime Scale
    Lime Scale
    Going to attempt the muriatic acid in a spray bottle approach to this problem. I have a few questions:
    1. Its a 5 water to 1 acid mix?
    2. What does it do to the grout?
    3. I intend to be in the pool when I do this as I can't see that sort of dilution causing any problems. ie: Will not be worrying about the family jewels being exposed.
    Any other tips?
    Thanks
    Plaster In Ground, with Waterfall Spa. Raypak Heater, Nautilus DE Filter DNS48. Built about 2000.
    30,431
    Re: Lime Scale
    What surface has the scale attached to?
    Re: Lime Scale
    It's on the tiles, around the water line.
    Regards
    30,431
    Re: Lime Scale
    5:1 is probably too weak. You can try it but, unless it foams up when it contacts the scale, you'll need to make it stronger. 3:1 works pretty well for me.
    It will attack the grout but not as aggressively as the scale. Avoid getting it on the grout (yeah, that's impossible, I know). Just apply it carefully and any that gets on the grout simply dilute immediately with pool water.
    Wear rubber gloves. Be sure to use a brush that is made to handle acid.
    Re: Lime Scale
    OK good stuff, thanks. I'll give it a go.
    Chris
    Re: Lime Scale
    Hmmm! I had a go at this approach. That could be a lifetimes work! Is there any paste like substance on teh market that can be spread on and then left awhile and washed off?
    Thanks
    30,431
    Re: Lime Scale
    What ratio did you use and what percent was the muriatic? Did it foam on contact?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Re: Lime Scale
    why not just use tile cleaner?
    Re: Lime Scale
    I used the strength that Dave suggested. Maybe I need to leave it on the tiles longer? I was a bit worried about the grout getting dissolved. Also, I had a kitchen scrub pad to work it in with, maybe I need a strong brush?
    Thanks
    30,431
    Re: Lime Scale
    If not, your solution is not strong enough.
    Jul 2011
    Central Califorina
    208
    Re: Lime Scale
    Just a thought in regards to the MA dilution ratio. Did you start out with 31.5 % or 15 %. obviously you will cut the 15% less.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    Feb 2008
    Denton, TX
    5,061
    Re: Lime Scale
    Quote Originally Posted by Aquatica
    You certainly could. Most of us have muriatic acid on hand already though. It works just as well to use the MA/water mixture.
