Thread: I need to lower my PH
    Apr 2010
    Central NJ
    227
    I need to lower my PH and wanted to know if this is what I should buy.
    http://www.homedepot.com/h_d1/N-5yc1v/R ... ogId=10053
    at the moment my PH is 8.2.
    thanks
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: I need to lower my PH
    Yes, that will work.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    That's the stuff. The MSDS shows 31.45% Muriatic Acid.
    Try to stay upwind when you open it. Or else you'll remember to next time!
    htownjeeper's Avatar
    Aug 2011
    Nassau Bay, TX
    199
    Quote Originally Posted by Richard320
    No doubt! The first time I was measuring out some MA, I did it in my garage and almost knocked myself out! I RESPECT the MA from now on!
    22,000 inground Fiberglass
    DE Filter Pentair FNSP 48
    Century Centurion 1.0 HP 1.25 S.F. 3450 RPM
