Thread: Closing pool in Va Beach
    Good Monday morning to all!
    Our water temp is still in the upper 70's so too warm to officially close, but I want to be prepared to close it the proper TFP way rather than the Pool Store way I've done in the past. So...my question is how do I close it properly? From what I've read so far, it looks like the water temp has to be in the 50's and then shock and put in an algaeacide?
    We keep our pool open all winter. We don't drain and blow out any lines as we have a built in system to turn on when the temp gets to 38 degrees. We've never had it fail before. (keeping fingers crossed) We do keep all the debris out during the winter and the water has always been clear until March when algae sets in but this year, with all the help from TFP, I will hopefully be able to combat that or not have as much of a problem.
    So...any tips for a TFP closing newbie? Thank you so much for your help.
    Mandy
    20,000 gallon fiberglass inground pool * Hayward sand filter and pump * Jandy Aquapure 1400 SWG * Jandy Aqualink Control System
    22,548
    Re: Closing pool in Va Beach
    Since you don't close it, I wouldn't worry about the algaecide. I would just maintain the FC using bleach during the times when the swcg won't operate. Test and adjust about once a week. Keep the debris out and next year once it starts warming up keep the FC up more regularly. If you do that you really won't have an opening, you'll just start swimming when it gets warm enough.
