Thread: What Does Clean Cell Tell US?
    Mar 2011
    Houston, Texas
    413
    The inspect cell light on my Aquarite was blinking which signifies that the 500 hour inspection was due. I inspected the cell and it was perfectly clean. Can I assume that because the cell was spotless that what I thought was scaling on my plaster is just normal mottling? In other words, if I have scale on my plaster does it follow that I should have scale in my salt cell? The Aquarite has the self cleaning feature so perhaps it should be clean regardless of whether I developed scale on my plaster. The cell is about six months old.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Jul 2007
    Brisbane, Australia
    874
    Re: What Does Clean Cell Tell US?
    i think it's more of a service reminder light on Aquarite. there is also a way to reset it.
    the scale on your plaster shouldn't necessarily transform to the scale on your cell
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    It's just a reminder to check it. If you look in the manual, it tells you how to reset the timer to get rid of the light.
    Mar 2011
    Houston, Texas
    413
    Quote Originally Posted by Melt In The Sun
    Yes, I understood that and I did reset the timer. That was not my question. My question was whether the prestine nature of the cell tells me that there could not be scale in the pool. The notion would be that the inside of the cell has higher pH than the rest of the pool and if scale will appear anywhere it would be inside the cell first.
    Strannik answered it and I'm guessing he's correct.
    Oct 2009
    3,899
    Yes, he is. Sorry I misunderstood you.
