Thread: Pentair Easy Touch Panel- No Power
    When I got home today I noticed the pool wasn't running so I went to the control panel and it was blank. I assumed a breaker had tripped but that wasn't the case. I went ahead and reset the breakers anyway and I still cannot seem to get my control panel to power up.
    Any ideas? It was working fine yesterday and we did not have any power outages etc. over night, not sure what happened?
    South Central NJ
    3,192
    Re: Pentair Easy Touch Panel- No Power
    Sounds like power to the sub panel tripped. Check the inside breaker feeding it.
    Scott
    Owner of - PoolGuyNJ LLC
    That was my first guess too, unfortunately it wasn't the problem.
    South Central NJ
    3,192
    If you have a multimeter, check the power at the transformer and for power at the relay line side connections.
    Scott
    Thanks for the replies. It ended up being a GFI that had been tripped that I wasn't aware was connected to this panel.
