Results 1 to 7 of 7
Thread: How much acid?
    Sep 2011
    Denton, Texas
    38
    How much acid?
    Since we'll be doing a follow up no drain acid wash, I would like to know the proper amount of acid to use. For a pool of 30,000 gallons advice has ranged anywhere from 6 to 12 gallons. There are a few remaining areas of original plaster dust that was not properly removed during the initial start up, and these areas are a bit stubborn. Most of the pool looks great, just want to get a nice uniform look throughout the plaster surface.
    During round one we used 5 1/2 gallons, and I was told we should have used more.
    So what is your advice?
    30,000 gal in-ground, Stonescapes Tahoe Blue, DE filter, Pentair WFE-30 filter pump, Saltwater Generated Chlorine.
    South Central NJ
    3,192
    Re: How much acid?
    How big are the areas? How many? Why isn't it being spot treated? There are pole attached appliances that look like a paint pad that can apply MA or bleach on a spot or swath.
    Scott
    Owner of - PoolGuyNJ LLC
    Sep 2011
    Denton, Texas
    38
    Re: How much acid?
    Quote Originally Posted by PoolGuyNJ
    Scott
    One patch is 2' X 6', another is 8' X 2', with two circle type patches about 2' in diameter. Plus there are a few areas on the wall below the spa. Seems a bit too big for a spot treatment...but I'm willing to try anything!
    South Central NJ
    3,192
    Re: How much acid?
    I would try this: http://www.puritypool.com/stainremovers.html
    The Underwater Acid Wash
    I have them and they work very well.
    Scott
    Sep 2011
    Denton, Texas
    38
    Re: How much acid?
    [attachment=0:kvzw0hqj]110_4012.JPG[/attachment:kvzw0hqj]Here is picture of one area at the bottom of the entry steps. Do you think the spot treatment you suggest would work well on this larger area? You can see the patch of light gray/blue that I'm talking about.
    South Central NJ
    3,192
    Re: How much acid?
    I would use the larger of the two pads. They come together when purchased. Piece of cake.
    Scott
    Sep 2011
    Denton, Texas
    38
    Re: How much acid?
    Scott
    Thanks, Scott! I'm going to check it out.
