Results 1 to 14 of 14
Thread: Helping a friend with his green swamp
    Guest
    So I've converted my green swamp, now I am helping a friend with his
    23000 plaster free form with DE Filter
    Did testing with my Taylor kit this morning and noticed that Calcium Hardness was 130...
    Should he address this before shocking? If not, when? What should he do?
    Pic from this morning:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Helping a friend with his green swamp
    We really need to see the other test results first. It may be beneficial to begin the process with cal-hypo, or there may be an adjustment needed to pH first. If you could post all of the test results we can give a better informed opinion.
    Love TFP? Become a
    TFP Supporter!
    As a general rule you deal with algae first, and worry about calcium later. Of course, zea3 is correct that low CH levels do make cal-hypo much more attractive for shocking.
    Guest
    Full test results:
    FC 0
    CC 0
    PH 6.8
    TA 80
    CH 130
    CYA 35
    I had him add two boxes of 20 Mule Team Borax to get his PH up and enough bleach to get to shock level 14ppm for round one
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Maintaining that shock level till the closing bell in round 15 is the secret........................
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    What a cute little pool! I want one of those.
    It'll be even cuter when it's sparkling. What a great friend you are! You did have him order his own test kit, right? Don't give up yours!
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Guest
    Update: After backwashing filter and adding DE he put in two boxes of 20 Mule Team Borax and four bottles of 182oz 6% bleach yesterday afternoon to get started. I haven't been over there yet but after three bleach treatments he says the pool is turning. I have not been able to get him to spring for the full FAS-DPD test kit yet, so he can only read FC up to 5ppm
    Guest
    Here is a couple of pics... first is Day 1, second is Day 2:[attachment=1:30mejmh5]friendspool1.jpg[/attachment:30mejmh5][attachment=0:30mejmh5]friendspool2.jpg[/attachment:30mejmh5]
    Guest
    Its been a real battle for my friend, but he is in the home stretch now:
    As the water is clearing he notcied that the plaster is real bad in a some spots, and he wanted to know what he can do to slow down the breakdown of the plaster.... I will try to get more pics.
    Could this be a result of his CH being so low? Once he is done shocking and clearing the pool what can he do?
    Guest
    My friend's pool has cleared I'm going to help him with the OCLT this weekend...
    Here are some pics in which you should be able to see some of the plaster deterioration in the bottom of the pool. Is his low CH level contributing to this? What should his next step be?
    Thank you all for the help
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Great job helping him get that pool cleared up I believe the only way to keep the plaster from deteriorating further is to keep the CH at the proper levels. I know there is some products for patching plaster, but those look like pretty big spots. I've got one spot in mine where the plaster has popped off and I can see the gunite, but it hasn't got any worse since I've lived here and kept the pool chemistry at proper levels(2 years).
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Mar 2007
    San Rafael, CA USA
    12,082
    It was probably a combination of low CH AND low pH and possibly low TA as well that contributed to plaster dissolving, but that would tend to cause pitting in larger areas whereas the photos look more like specific areas with plaster problems. When plaster deteriorates due to bad water chemistry, it tends to feel rough almost everywhere it is exposed to the water, though some areas of poor circulation could be worse than others.
    Guest
    What is the recommended method for getting his CH up to normal levels? Test results before shocking showed CH at 130...
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    calcium chloride/Deicer pellets such as: Qik Joe 40 Lb Ice Melt Pellets Calcium Chloride
